1 - 9 of 9 Posts
It is difficult to get Imperial sized air pipe over here in England (which is ridiculous because we are not totally metric over here, despite what you might think). 216RIDER used 5/32" air pipe for his gauge lines with 1/8" fittings/adapters for the increased pipe size.
Would I be able to use 1/8" air pipe for my gauges and not use the adapters, or doesn't 1/8" air pipe exist. If it does exist, would the pipe be large enough to be effective.
I like the idea of tapping an adapter into the T-pieces right up by the air tank.
Thanks
:0 :uh: Oh!
I presume that all the sizes we talk about are American sizes. Forget the imperial bit, I presumed that American sizes were imperial!
Right, can I use American 1/8" line for my gauges instead of 5/32"?
Thanks!
The lines used in USA ( Example 1/8") will be true 1/8" outside ( 2.5mm)
Becarful trying to size NPT ( USA ) against BSP ( UK ) they are different..........Alot......
( 1/8" NPT about the size of 1/4" BSP )
BSP = "British standard pipe"
Thanks jjj.
Failing the 1/8" idea, I wonder if I could tap a 1/4" fitting into a 1/2" T-piece to run 1/4" lines to my gauges?
I intend to stick to USA fittings, lines and gauges all the way through ;) .
The only question remaining is if a 1/2" T-piece is large enough physically to tap a 1/4" fitting into it.
My set up (inspired by 216RIDER's set up) would be: 1/4" fittings tapped into the main T-piece after the inflation solenoid, 1/4" lines to the gauges, then 1/4" fittings on the backs of the gauges :cheesy:.
I'll investigate and let you know if I manage to find out.
1 - 9 of 9 Posts
