1 - 20 of 20 Posts
just wondering if anyone knows how hard it is to do shaved door handles and install door poppers on a gbody, and what weight poppers would be good?? :cheesy:
g body latches pull really easy, they can be pulled with a 15lbs solenoid. But if you keep the inside door handle it has to move that as well so then you need some more power. Plus if you want it to be reliable you need to go with atleast a 35lbs. Spal makes a good kit. Ive installed these on g bodys and other cars, theyve lasted on a daily for 7+ years now.
http://www.speedwaymotors.com/SPAL-SHAVED-...Y-KIT,2425.html
Spall in an S10 I did 4 years ago and still thunk like a mofo. The only problem was the poppers them selves, got em on ebay and the rusted and need lubed every so often. The Spall electronics are simple and solid.
COO! ALL GOOD INFO GUYS! I HEARD U CAN DO BODY FILLER WHERE THE HANDLES USED TO BE AND BONDO IT EVEN INSTEAD OF WELDING. GOOD TO DO OR NOT??
NO!!!! Don't just mud over where the handles and locks are. You need to weld some metal in there, but be carefull not to warp it up by taking your time. If you simply bondo over it - it WILL fail on you. Good luck....... :cool:
what a fucken coincidence my passanger side just went out. thats the one i hardluy use :angry:
[/b]
<!--QuoteBegin-Airborne
@Nov 19 2008, 06:48 PM~12204426
all of the components i have looks similar to spall. might be spall but dont know. the only thing that does'nt look the same is the popper.
coo so im better off taking it to da shop for this then?? :biggrin:
If you can find a friend or someone that can weld it for you. If not yeah I would take it to a shop. At least have them do the parts you aren't comfortable doing yourself. When it comes to putting in the solenoids/poppers to open the door that stuff is pretty straight forward and easy.
yea i plan on doing most of da shit myself, interior, all da custom work, only thing dats going to da shop is frame wrap, and paint job w/ pinstriping. everything else i wanna do myself...or at least try to. :biggrin:
Like they said be careful when welding, sheet metal can warp. Tell them not to run a bead around the metal filler piece, just tack it in, sand/grind down the welds and use filler. The less filler you use the better because after you spend money to put paint on you dont want filler shifting and causing a crack in the paint! If the body is curved, make the filler piece curved to follow it, remember, less filler is better!
The Great White Hype
x2, if it gets warped you will be doing this to your doors
not fun to fix. DONT WARP YOUR DOORS :yessad:
Discussion Starter · #15 ·
DAMN DAT LOOKS LIKE MECHANICAL ACCUPUNCTURE...LOL
BUT NOT FUN AT ALL :uh:
Originally posted by CoupeDevilleDTS@Nov 21 2008, 06:20 PM~12223251
cmon, just slap some bondo in there, its body filler aint it??  :biggrin:
remind me to not let you work on my car :biggrin:
1 - 20 of 20 Posts
