but will not start - 1992 Camry anyone got any ideas? This happend when I had to change one of the fuel lines that I fucked up.
Originally posted by Foompla@Oct 1 2006, 04:33 PM~6283868
if your getting correct spark and correct fuel, check compression.
That says it all... If they are correct....
Do you get any kind of poping or wanting to start???????
Is it fuel injected??? Is the timing OK....
Triple OG
you probally have air in the line...
what happens when you try?
btw...how do you know your getting fuel and spark?
check air in the fuel line then if its not that check your fuel filter maybe it is clogged...then check your ignition coil
