k this is my setup right now, i got two hoppos pumps, #11 to the front, and a #9 to the back.
k im gona be pickin up a pro hopper comp pump soon for my third pump, and i plan on running it to the front to replace the hoppos #11 thats already there.
what i want to do is take that hoppos #11 pump and put it to the back, so the rear is double pumpd
my problem is, that if i run the two hoppos pumps to the rear, they'll be mismatched because one is a #11 and the other is a #9.
if i buy another #9 gear, what other stuff would i need in order to replace the #11 with it?
is it a bitch to take out or can it be done pretty easily?
the battery voltage is gona stay the same, its gona be 48v to the two rear pumps
and the same 72v to the front
the pro hopper pump has a #13 in it, do you guys think 6 batts is enough to power that mofo?
