57481 - 57492 of 57492 Posts
What's up homie I got 8 in mine in the front and 14 in the back coil over in my 74 impala[/QUOTE]
Cool, is that just a regular lay & play setup? I just got my 75 impala and changing out the cylinders and was thinking of running 8’s and 12’s.
Gonna pick up cylinders tomorrow so wanted to make sure
Gonna pick up cylinders tomorrow so wanted to make sure[/QUOTE]
I have 4 pump 8 battery bridge in front and back my car stand 3 wheel like nothing no weight just pumps and battery
What modifications would I need to do so I can ride locked up? Have 8s in front with 2 ton pre cut springs and 12s in rear with 1 ton pre cut springs, only have stress points reinforced. 2 pump 8 battery setup
Well i could pretty much do with whatever on my set up but i drive lock up like about 12 in the back even though i have 14 but the reason is that is because i got a bridge in the back with chains.. but i think your gonna have to do some modifications on the drive line and u joints but when u put ur stroke tap up a little and drive you will hear the difference right away
You should be able to...soften up the rubber/adhesive first with a hair dryer and use a metal putty knife...trick is being patient depending on how brittle they are...if it breaks, glur back together then repaint...ive had a few glasshouses in my day...
I saw the homie use a torch from the inside of the bumpers and glue came loose.
Moderator
Here’s an update of mine
2023439
