1 - 20 of 49 Posts
NOW PLEASE BEFORE ANYONE GETS ON THIS TOPIC...PLEASE DONT TRASH THIS TOPIC...MIKE ISNT STARTING THIS NOR IS HE ON LAYITLOW ANYMORE...SO PLEASE JUS LET THIS ONE BE...IM NOT ASKING MUCH... :)
here is the over stock we have the first price is whats for sale and the second price is the full price for the part thats for sale.
Piston pump: $559 /$649 retail
1inch check valve: $61 /$70 retail
Y blocks: $34 /$40 retail
3/8th check valves: $28 /$34.99 retail
Half inch check valves: $38 /$45 retail
3/8th slow downs: $32 /$39 retail
Half inch slow downs: $42 /$48 retail
Black end cap motors(Chrome): $72 /$88 retail
Ball bearing end cap motors: $94 /$110 retail
3/8th Blocks: $55 /$68 retail
Tanks: $22 /$29 retail
Solenoids: $4.50 /$6.50 retail
Rockford pump heads: $72 /$89 retail
Telescopic cylinders: $250 /$299 retail
Springs: $78 /$99 retail
Doughnuts: $4 /$5.50 retail
End caps: $20 /$26 retail
Quick disconnect: $18 / $22 retail
15ft hose #6 : $29.99 /$48 retail
15ft hose #8 : $36 /$52 retail
3ft hose #8 : $14.95 /$18.95 retail
3ft hose #6 : $12.49 /$16.95 retail
Pump head bolts: $0.69 /$1 retail
Carling switches: $9.95 /$11.99 retail
Switch plates
*three 4-panels: $8.95 /$10 retail
*six 6-panel: $9.95 /$12 retail
Ten switch-switch box: $69 /$89 retail
LA dumps: $215 /$249 retail
Delta dump cartridges: $22 /$29 retail
Delta dump blocks: $12 /$15 retail
Fast bag air ride kit: $799 /$899 retail
Nock-offs: $20/nock-off
Nock-off hammers: $23.99
Adex rebuild kit: $19 /$24 retail
Keys: $3.99 /$6.50 retail
Piston steal tank combo zink finish: $249 /$289 retail
Tank o-ring $3.59 /$5 retail
here also are all the kits for sale from hi-low hydraulics the price in the perenthasis is the sale price and the price without the perenthasis is the retail price
PERFORMANCE 2000 KITS
HL132-01 PERFORMANCE 2000 FRONT KIT ONE PUMP $474.00 ($456.00)
HL132-02 PERFORMANCE 2000 REAR KIT ONE PUMP $464.00 ($442.00)
HL132-03 PERFORMANCE 2000 F-B-S-S KIT 2 PUMP $999.00 ($950.00)
HL132-04 PERFORMANCE 2000 F-B-S-S KIT 3 PUMP $1,299.00 ($1,235.00)
HL132-05 PERFORMANCE 2000 F-B-S-S KIT 4 PUMP $1,549.00 ($1,435.00)
CHROME/CHROME UPGRADE ADD PER PUMP $99.00 ($95.00)
THE HI-LOW SERIES KITS
HL133-01 HI-LOW FRONT KIT ONE PUMP $574.00 ($535.00)
HL133-02 HI-LOW REAR KIT ONE PUMP $564.00 ($525.00)
HL133-03 HI-LOW F-B-S-S 2 PUMP KIT $1,135.00 ($1,125.00)
HL132-04 HI-LOW F-B-S-S 3 PUMP KIT $1,449.00 ($1,335.00)
HL133-05 HI-LOW F-B-S-S 4 PUMP KIT $1,709.00 ($1,630.00)
CHROME/GOLD UPGRADE ADD PER PUMP $185.00 ($175.00)
THE ELIMINATOR SERIES
KITS INCLUDE : 1/2" CENTER PORT BLOCKS, BLOW PROOF
DUMPS, ELIMINATOR CYLINDERS,PARKER SLOW DOWNS-
PRESTOLITE SOLENOID BLOCKS AND STEEL BRAIDED RETURN
HOSES
HL134-01 ELIMINATOR FRONT KIT ONE PUMP $674.00 ($625.00)
HL134-02 ELIMINATOR F-B-3W 2 PUMP KIT $1,329.00 ($1,450.00)
HL134-03 ELIMINATOR F-B-S-S 2 PUMP KIT $1,409.00 ($1,335.00)
HL134-04 ELIMINATOR F-B-3W 3 PUMP KIT $1,679.00 (1,454.00)
HL134-05 ELIMINATOR F-B-S-S 3 PUMP KIT $1,769.00 ($1,625.00)
HL134-06 ELIMINATOR F-B-S-S 4 PUMP KIT $2,079.00 ($1,925.00)
CHROME/GOLD UPGRADE ADD PER PUMP $205.00 ($195.00)
THE ELIMINATOR MINI SERIES KITS
HL135-01 ELIMINATOR MINI F-B-S-S 2 PUMP KIT $1,450.00 (1,320.00)
HL135-02 ELIMINATOR MINI F-B-S-S 3 PUMP KIT $1,790.00 ($1,450.00)
HL135-03 ELIMINATOR MINI F-B-S-S 4 PUMP KIT $2,100.00 ($1,995.00)
PRO ELIMINATOR SERIES
KITS INCLUDES: 1/2" PRESS CENTER PORT BLOCKS, SQUARE
IMAGE DUMPS, ELIMINATOR CYLINDERS, MASTER BALLS,
REVERSE DEEP CUPS,PARKER SLOW DOWNS, PARKER
CHECK VALVES 1/2", SOLENOID BLOCKS AND STEEL BRAIDED
RETURN HOSES
HL136-01 PRO-ELIMINATOR F-B-3WHEEL 2 PUMP KIT $1,989.00 ($1,850.00)
HL136-02 PRO-ELIMINATOR F-B-S-S 2 PUMP KIT $2,359.00 ($2,230.00)
HL136-03 PRO-ELIMINATOR F-B-3WHEEL 4 PUMP KIT $2,849.00 ($2,612.00)
HL136-04 PRO-ELIMINATOR F-B-S-S 4 PUMP KIT $3,149.00 ($2,912.00)
ADEX DUMP UPGRADE ADD PER DUMP $190.00 ($185.00)
CHROME/CHROME UPGRADE ADD PER PUMP $105.00 ($102.00)
CHROME/GOLD UPGRADE ADD PER PUMP $210.00 ($206.00)
ELITE 2000 SERIES THE BALLER'S KITS !
KITS INCLUDES: 1" PRESS PORTS BLOCKS, ADEX DUMPS,
MEGA CYLINDERS,MEGA BALLS, MEGA REVERSE DEEP CUPS
PARKER SLOW DOWNS, PARKER CHECK VALVES AND
SOLENOID BLOCKS AND STEEL BRAIDED RETURN HOSES
HL137-01 ELITE 2000 F-B-3WHEEL ADEX 2 PUMP KIT $2,995.00 ($2,810.00)
HL137-02 ELITE 2000 F-B-S-S 2 PUMP ADEX KIT $3,465.00 ($3,267.00)
HL137-03 ELITE 2000 F-B-3WHEEL 4 PUMP ADEX KIT $3,949.00 ($3,740.00)
HL137-04 ELITE 2000 F-B-S-S 4 PUMP ADEX KIT $4,379.00 ($4,211.00)
CHROME/CHROME UPGRADE ADD PER PUMP $115.00 ($110.00)
CHROME/GOLD UPGRADE ADD PER PUMP $220.00 ($215.00)
SINGLE PUMP EXTREME HOPPING KITS
KITS INCLUDE SQ IMAGE DUMP FOR FRONT PUMP,
MASTER BALLS, REVERSE CUPS AND 14"CYL FOR REAR
AND DELTA DUMPS FOR REAR
HL155-02 HI-LOW HOPPING SP F-B-3WHEEL 2 PUMP KIT $1,549.00 ($1,432.00)
HL155-28 HI-LOW HOPPING SP F-B-3WHEEL 3 PUMP KIT $1,859.00 ($1,750.00)
HL155-09 ELIMINATOR HOPPING SP F-B-3WHEEL 2 PUMP KIT $1,799.00 ($1,665.00)
HL155-29 ELIMINATOR HOPPING SP F-B-3WHEEL 3 PUMP KIT $2,139.00 ($1,815.00)
HL155-16 ELITE 2000 HOPPING SP F-B-3WHEEL 2 PUMP KIT $1,899.00 ($1,765.00)
HL155-27 ELITE 2000 HOPPING SP F-B-3WHEEL 3 PUMP KIT $2,249.00 ($2,132.00)
HL155-28 ELITE NITRAULICS HOPPING SP F-B-3WHEEL 2 PUMP KIT $2,139.00 ($1,988.00)
HL155-29 ELITE NITRAULICS HOPPING SP F-B-3WHEEL 3 PUMP KIT $2,489.00 ($2,350.00)
CHROME/CHROME UPGRADE ADD PER PUMP $115.00 ($100.00)
CHROME/GOLD UPGRADE ADD PER PUMP $220.00 ($210.00)
UPGRADE TO ADEX DUMP ADD $185.00 ($175.00)
NOTE : ELITE 2000 KITS COME WITH ONE ELITE 2000 PUMP
FOR FRONT AND ELIMINATOR PUMPS FOR REAR
DOUBLE PUMP EXTREME HOPPING KITS
KITS INCLUDES ONE ADEX DUMP FOR FRONT PUMPS
MASTER BALLS, REVERSE CUPS , 14"CYLINDERS AND
TWO BLOW PROOF DELTAS FOR REAR PUMPS
HL159-01 ELIMINATOR HOPPING DP F-B-3WHEEL 3 PUMP KIT $2,249.00 ($2,115.00)
HL159-02 ELIMINATOR HOPPING DP F-B-3WHEEL 4 PUMP KIT $2,580.00 ($2,315.00)
HL159-03 ELITE 2000 HOPPING DP F-B-3WHEEL 3 PUMP KIT $2,499.00 ($2,350.00)
HL159-04 ELITE 2000 HOPPING DP F-B-3WHEEL 4 PUMP KIT $2,799.00 ($2,450.00)
HL159-05 ELITE NITRAULICS HOPPING DP-F-B-3WHEEL 3 PUMP KIT $2,899.00 ($2,681.00)
HL159-06 ELITE NITRAULICS HOPPING DP-F-B-3WHEEL 4 PUMP KIT $3,199.00 ($2,900.00)
SQUARE IMAGE DUMPS UPGRADE PER DUMP $220.00 ($195.00)
NOTE : ELITE 2000 KITS AND NITRAULICS KITS COME WITH
you can get ahold of me at 608.719.9456 or you can pm me you can also call mikes phone at 608.446.2351
thanks!
Originally posted by ars!n@Jan 20 2010, 11:56 PM~16359602
TTT Whats good mamii. Tell Mike I said whats up
i will do so!!
Mike is using this account now.
Giving out threats should get your scammer ass banned!
beware dont paypal these people!
no hes not...if you dont believe than thats to bad...dont try to get me banned because you dont like mike...jus stop please!!!!!
lay it low also has a "for sale" section.
maybe thats were you should be trying to "sell" this crap.
Banned
Get off his dick already. You're a annoying little child. Go play with your model cars already. You spend all your time running your mouth and when someone says some shit about it you go running to the mods and get them banned.
And the "Snitch of the year award goes to......"
You should spend a little less time in front of your computer screen and more time on the streets so you can see real cats don't play these little high school games. I bet your old lady is the one that gave you the name "SinglePumpKing" :uh:
i learned along time ago to follow my gut feeling with people and i have always been right. u don't have to prove nothing to noone. you do what you have to do to keep your family going. and know you have good people behind you. cockroaches just get bigger as you feed them. your letting this one under your skin. the only people you need to worry about are the ones that can come to you face to face and have something to say. don't give this one the time of day. i know you and mike and i trust you with my 67. i will be proud to say that delarosa customs built my car :biggrin: :biggrin: :biggrin:
Banned
Originally posted by babie is nana 13@Jan 21 2010, 04:40 PM~16366951
i learned along time ago to follow my gut feeling with people and i have always been right. u don't have to prove nothing to noone. you do what you have to do to keep your family going. and know you have good people behind you.  cockroaches just get bigger as you feed them.  your letting this one under your skin. the only people you need to worry about are the ones that can come to you face to face and have something to say. don't give this one the time of day. i know you and mike and i trust you with my 67. TTMFT For Delarosa Customs and nada for you haters ;) </span>
Discussion Starter #13
awww nana i love you!!!!! =D that made my night!!!!!!!
and thank you arsin...you both made my night!!!
=D =D
Discussion Starter #14
Originally posted by 817Lowrider@Jan 21 2010, 02:55 PM~16365107
for the beautiful young lady.  :cheesy:
<3
well thank you!
that made me lol :roflmao:
:rolleyes:
fuck you
:wow:
dont paypal these people or give them credit cards.
they are scammers, use threats and hacks.
I can post pics of the work he does, its terrible.
Dont support scammers! beware!
1 - 20 of 49 Posts
