1 - 10 of 10 Posts
where is the best place for the ground is side of the car because i have mine grounded to the floor of my car and it seems like a week ground for the switches and i was wondering if it would be better if i cut a small hole in the floor and grounded it to the frame thanks sorry for the new be post but this is my frist car with switches in over 6 years so i dont remember were to ground :cool: thanks
sorry i forgot to say it,s ran under the driver seat
that. s also where my disconect is under the driver seat grounded to the flor board i dont think it,s right
put a 3/8 bolt through your floor under the seat
put a 1 foot cable under the car ,from the bolt to your frame
then bolt the quick disconnect cable on top under your seat
make sure you grind the top and bottom of your floor board where you drill so you can have a better connection
thanks bro that,s what i was thanking about but i wanted to hear it from some body else before i did it thanks again :cool:
thats fine if you racks are welded to the frame. better to run a cable from the rack. ;)
when you've cranked the bolt through the floor tight (with a shake proof washer on it) cover it with silicon or some other sealant to protect the clean metal and prevent water contamination leading to rust and also a bad connection.
Good thinkin Unity Jon!!!
1 - 10 of 10 Posts
