1 - 20 of 36 Posts
HOMEWORK!!!!!!
ok thru alot of research i have FINALLY came across a company that makes these weatherstrippings that are hard to find, better get em while u can cause they will be discontinued soon im sure :cool:
the weatherstrippings that goes around the glass for a 2dr 80-84 deville and 80-85 fleetwood are called (window run channels).. they have them for $92 shipped
and also the glass sweeps that sit at the bottom and go on the inside and outside (2 peice) are $150 a set.. they make both sides, so 4 $300 and some change for all 4 you need..just add shipping (these still are availible for both sides inside and out)
from
North Yale auto parts
11506 North Yale avenue
Sperry, Ok . 74073
1-800-256-6927 (m-f)-8am-5pm
also u can purchase these hard to find outer sweeps that sit at the bottom of the glass for only $33 bucks a side from 1aauto.com thats where i got mine 3 years ago but they seem to still have them
Drivers side
http://www.1aauto.com/1A/Weatherstrip/Cadi...ille/1AWSS00027
Passengers side
http://www.1aauto.com/1A/Weatherstrip/Cadi...ille/1AWSS00028
as for the door jamb and trunk strippings can still be bought at steelerubber.. YOUR WELCOME :biggrin:
iv seen that last year a member here posted it!! the one with the clean coupe with the mods like clean front and rear bumper etc. cant remember the name!!
but i think it was dekay or something like this!!
to bad they dont make it for the 4door
but if someone will run across these 4door parts please lmk asap!!i need em really bad
if someone run across these 4door parts please lmk asap!!
try them they might have em, most likely :cool:
its a lil hard for me to check it out cause im from germany!! but would really appericate it if u can check it out and lmk!!!
or do they have a website
yes they have a site on ebay... :cool:
i need the outer sweeps!! been going crazy. i thought the ones for the box would fit, but they are molded onto the chrome trim.
so is this just the rubber sweep itself or sweep and molding?
Originally posted by DEAD PRE$IDENT$@Jan 22 2010, 02:14 PM~16376227
:0
from
Sperry, Ok . 74073
also u can get just the outer sweeps that sit at the bottom for only $33 bucks a side from 1aauto.com
Finally you found what you were looking for brah!!!! :biggrin: :cool:
pm me the ebay name :) :0 ;)
North yale auto parts, i want the word out, we need to keep these in production ;)
Discussion Starter #11
these are just the rubbers, you just have to rivet your aluminum moulding to these new rubbers :) hope this helps man :happysad:
Discussion Starter #12
:cheesy: Finally, i was worried like crazy, just another key to the puzzle, watch 5 years from now you wont be able to get anything like these, then those who wanna restore these lacs will be assed out :wow:
Discussion Starter #14
Originally posted by R.O. caddy man@Jan 23 2010, 10:24 AM~16384493
Billy ur the man :biggrin:  ;)
:happysad: just trying to help a brotha out :biggrin:
good info Billy :thumbsup:
you should post this in the 80-90 fleetwood classifieds too :cool:
Good info billy :cool: What's intresting to me is never once did I thought about looking up the Olds Delta 88 coupes when I was looking for them :happysad:
These may have to be cut and trimmed i got a set for the outside of my caprice and they took a bit of altering to sit right and i had to trim them on the ends. I also heard from people that they will start to get wavy from the sun beatin on them not sure but better than nothing or cracked
Discussion Starter #18
yep delta 2ds basically have the same door and glass and gutter trim.
yes it does. i had found some clean 2 door caprice ones at pickin pull but the caprices are molded to the trim. i have to get me these for sure. after these i can finish putting my windows in . :puffin:
[/b]
yeah thats true
i have look on ebay but cant find em and i tryed all combos out from the name? u got a link to an auktion??
maybe im to :420: its 4 am here :)
<!--QuoteBegin-DEAD PRE$IDENT$
@Jan 23 2010, 08:16 AM~16384469
iv look for the same time but no luck too :uh:
1 - 20 of 36 Posts
