1 - 20 of 22 Posts
what exactly is the name for them,,,that goes on end of double flared hardlines?..anybody got a part # or more info bout this,would be greatly appreciated....thankx,,MO
yeah,,,dont u need double flaring tool?,,that would be double flared?
im assuming,,that what u need if it was 3/8'' would be,,,3/8'' stainless stell compression fittings.....???
Face Puncher
[snapback]3452681[/snapback]​
well, if you go with compression, then no flares needed.
otherwise you need to go with 37° flares, also known as JIC fittings.
save the double flare tools for your brakelines ;)
[snapback]3453029[/snapback]​
Same fittings are used For AN, but they are not the same pressure rating! ;)
what does people normally use?..more info,and pics, part number,,all that good stuff,,,,list of what i need besides the tubing itself
Face Puncher
[snapback]3453130[/snapback]​
flare tool
tube bender
fittings
talent
just hit up the parker store
Originally posted by 216RIDER@Jul 21 2005, 09:55 PM
flare tool
tube bender
fittings
talent
[snapback]3453155[/snapback]​
or you could hit me up :biggrin:
i have benders, and flaring tool, and tubing,,,just not sure bout fittings,,,ive practiced doin bends and all that,,i got that down pact...just need more info on connectors,fittings or whatever
Originally posted by air280@Jul 22 2005, 02:43 AM
as 216 says, use Parker flaring tools and nuts. compresion ends are easier but flares are neater and more secure
[snapback]3455186[/snapback]​
i think the neater and more of an opinon because i personally don't like them
i think the compression looks better.
Face Puncher
[snapback]3459179[/snapback]​
no sleeve to see. ;)
how do the compression fittings work exactly? all the fitting i got are the type you need to flare and if i can get away with not having to that would be cool...
Face Puncher
they have a ferrule that bites into the tube, and provides the seal and the mechanical retention all in one
Discussion Starter · #18 ·
[snapback]3459246[/snapback]​
is it close to the same principle as air lines, for air bag set-ups?,,,how it has the ferrel, and all that
Originally posted by Chris@Jul 22 2005, 01:44 PM
and most hydraulic places will have these?
[snapback]3459259[/snapback]​
all you do it tighten the flareless fitting (Swagelok,Parker) and the ferrul tightens on the stainless tube.
go to ebay.com and type swagelok and thats the fitting they use
1 - 20 of 22 Posts
