Against the Grain
Im gonna be doing my first hardlines setup and was wondering if 3/8 .32 stainless steel will be strong enough to withstand the pressure of a simple 2 pump hydraulic setup just being used to fbss and dogleg. will be just prox blocks, chrome saco motors, and #10 heads, delta dumps. So I doubt I'll be sending out too much psi. Thanks.
True-S Mike
this MAY help......... most say .035 in stainles is ok for returns only. i have serched all hardline threads on this site and i see people pushing .049 and up for pressure.
you didint list what volts your gonna run to your motors.
SELL 0UT
ive seen people bl ow out return lines from hopping.. they will blow before the pressure lines will.. i would do both with .049 and up.. ive blown out 2 return lines hopping.. and my buddy has blown out a couple also.. #8 return lines that werent in a bind
Originally posted by red_ghost@Oct 11 2006, 07:22 PM~6350091
Im only doing 24v to each pump.  sorry about that.  Like i said, this car isnt going to be for hopping, just fbss and dogleg (its fwd).
are you sure its .32??
anyways i had a setup for front, back at 24v to each pump and i had no problem...and i had both pressure and returns in 3/8 .035.....I just never did any dogleg :)
