every time i fix one leakng cylinder it seems like the back cylinder starts leaking real bad and man i hate that shit i might have to move to the new 3seal cylinder huh?
YEAH THAT MIGHT BE THE PROBLEM OR I MIGHT BE USEING HEAVY DUTY OIL WITH DETERGENT IN IT I HEARD TOUSE NON DETERGENT OIL AND YOU WONT GO THROUGH SEALS?Originally posted by bounce13@Mar 12 2010, 12:48 AM~16867659
when you changed the seals did you hone out the cylinder? that could be one of your problems and you should change your oil it might have some crap floating in it and its going into the cylinders and killing your seals
dont just replace the seals..use good ones...get some poly pak seals for those cylinders unless they are scared up on the casing wall..but i have poly paks in my car and one set is 2 years old and the rears are over a year old and havent touched them since...i been using poly pak seals since 2005Originally posted by pauls 1967@Mar 12 2010, 01:37 AM~16867564
WHERE CAN YOU GET THE POLY PAK SEALS? AND WHERE YOU STAY AT I WOULD LIKE TO GET AHOLD OF SOMEOriginally posted by KINGFISH_CUSTOMS@Mar 12 2010, 01:10 AM~16867807
we can send them out to yaOriginally posted by pauls 1967@Mar 12 2010, 02:24 AM~16867868
i bought some locally and paid 10.00 a ring, and they are a bitch to put on, but worth itOriginally posted by pauls 1967+Mar 12 2010, 03:00 AM~16867738-->use non detergent. the detergent dries out the o rings and causes them to deteriorateYEAH THAT MIGHT BE THE PROBLEM OR I MIGHT BE USEING HEAVY DUTY OIL WITH DETERGENT IN IT I HEARD TOUSE NON DETERGENT OIL AND YOU WONT GO THROUGH SEALS?
[/b]
<!--QuoteBegin-pauls 1967@Mar 12 2010, 03:24 AM~16867868
They only work one direction. You have to put them like this \| |/ so that the pressure from the pump pushes the seal tighter against the wall of the cylinder. If you put them like this /| |\ Then the oil will just go past the seal.Originally posted by HARDLUCK88@Mar 12 2010, 03:33 AM~16868160
i bought some locally and paid 10.00 a ring, and they are a bitch to put on, but worth itmake sure you put the skirt side of the seal facing inboard to each other...
not true..ive actually put them with the lips towards the bottom and they work just fine..Originally posted by Lord Duez@Mar 12 2010, 10:27 AM~16869649
Originally posted by HARDLUCK88@Mar 12 2010, 04:47 PM~16872857
this is how i did it
Originally posted by Lord Duez@Mar 12 2010, 07:31 PM~16874395
This how I would see it working. I would assume that using two facing different directions means only 1 is working.
ONCE A YEAR DONT COUNT :twak:Originally posted by KINGFISH_CUSTOMS@Mar 12 2010, 04:18 PM~16873132
Also I have a set of poly paks on my front cylinders and they are about 2 yrs old if not older and i hop on them. No leaks.
then u have no back up O ring if the other failsOriginally posted by AndrewH@Mar 12 2010, 10:04 PM~16876060
you shouldnt be using 2 'poly paks' in the first place, in my opinion. Only the bottom one.
