1 - 14 of 14 Posts
Originally posted by UCYI3WL@Aug 27 2003, 11:56 AM
What is the best headliner glue to use?? Looking for long term hold with no sagging later on from heat
Thanks
elmers wood glue applied evenly with a roller. :thumbsup:
j.k. you gotta use the contact cement from a 5 gallon bucket,sprayed out of a gun that stuff that they sell at the parts house sucks testicals.if you want permanent hold never NEVER USE AEROSOL CAN FOR ANYTHING! :biggrin:
Thanks for the help...I picked up a quart of glue/contact cement that can either be sprayed with a gun or brushed on wth brush...Will brushing this on hold just as good as a spray gun??
thanks for the help man ;)
JUST BUY A CHEAP PAINT GUN,THATS WHAT WE ALL USE.THE 3M STUFF SUCKED IN MY EXPERIENCE I DIDNT LIKE IT AT ALL AND WAS WAY TO PRICEY!IF YOU BRUSH IT ON YOU'LL BE THERE ALL DAY,BEST TO SPRAY BOTH SIDES FOR PERMANENT ADHESION PM ME IF YOU NEED ANY FURTHER ASSISTANCE ONCE YOU GET STARTED! :biggrin:
even when i used the can stuff wich yeah sucked and bubbled, it would kinda come through on the velvet is the paint gun that much thinner?
there was one good aerosol glue that i used before. held almost as good as the stuff we used in the spray guns...its comes in a white can with blue lettering on it...very basic looking nothing fancy...its got a simple ass name but i just cant think of it...."name started with a J i think, like jeffco or something co" 3m works if your just doing simple shit but something like that has weight to it...just buy a 20$ spray gun and go to an upholstery shop and try to buy some of their glue..thats what i do now
INSTABOND :thumbsup:
never heard of instabond....this stuff was named real simple....and it was really cheap to...about 2$ a can...think it just said high strength spray adhesive on it...i think the biggest reason it was strong is because it didnt spray out all fucked up like 3m spray adhesive...it actually spread more like a spray gun....nothing is better than that stuff in the 5 gallon buckets though...but you better hope you stick it just right because it isnt coming loose once you do it :roflmao: :roflmao: :roflmao:
there's several glues you can use
camie has a #300 and #303
k-grip #701
3m #90
3m #1099
if the headliner is
cloth - 3m #90
if its vinyl - 3m #1099
these two 3m #'s are both high temp adhesives which is what you want.
hope this helps :),
cc
1 - 14 of 14 Posts
