What up peeps, can someone shed a lil info on a promblem w/ my pump. Here's what's wrong, motor wont spin w/ pump together, take motor off and motor spins. So I think my pumphead has locked up. Next I took the pumphead off and gears seem to spin fine unless its something I not seeing. Please all opinions and answers wanted.
Holla
seems pump isnt grounded, or your key is binded up ;)
1980 Cadillac Fleetwood 90’d out
How are you grouning your mottor without the block? Try to put the motor back on and ground the block the same way. If it works then. Your block is not providing a good enough ground. Tell us how your system is set up or post a pic. Were is your ground for the batteries connected? The rack? Or the car? How is your rack mounted? Are the batt./pump rack mounted together? or separate?
