P
PIMPOLOGY
·Guest
Anyone have some step by step pics doing a chop top roof and how too cut down the safety glass. I have a pritty good idea how it goes but any extra info would be tight !
Great tip, i'll play around with this idea and see how it goes.. What type of rides have you chopped?Originally posted by hot$tuff5964@Dec 21 2006, 01:44 PM~6798712
ive done a few chop tops. the first thing i always do is, and its gonna sound crazy, get 3 pictures of it, one from the side, one from the front, and one from the rear. now chop each picture/drawing like you were cutting across the top to chop and remove a little bit of the metal/paper, and put it back where it belongs. now you should have an idea what is gonna come into play. more than likely you will have to cut again going the other way to accommodate for the taper of the roof and make it wider. most chops require cutting the roof in to 4 pieces and then filling in the gaps either with a donor roof or sheet metal.
