help set up failure
438 Views 12 Replies 9 Participants Last post by  bigdaddys63
my back pump goes clik clik clik when i hit the switch but it wont go up or down ,,oil is full,, bateeries are full, cables are tight help,,,,,,
1 - 13 of 13 Posts
either batts need charged, bad ground, or bad cyloniod or dead batt causing the batts to lose charge
TRY JUMPING IT OVER THE SOLINOIDS, USE A PAIR OF JUMPER CABLES AND CLIP IT TO 24 VOLTS THEN TAP IT ON THE POS TERMINAL ON THE MOTOR AND IF ITS THE NOIDS THE CAR SHOULD LIFT
Sounds like a Solenoid problem....
it could be your motor also... but more than likely its your solenoid.
thanks homies ,, i will change the silenoids first,, if not i will jump them, i will recharge the batteries,,cuz i ook the moor apart and is clean inside
make sure the pump is grounded good, then jump the motor to the 12 volt (first battery) connect the cable to the motor , then tap it to the battery. then go from there
if the pump motor is clicking its an Earth problem, if the solenoids are clicking, they're working but the motor isn't spining, assuming the motor is good, its an earth problem ;)
finally fixed it ,,,,,,,,,,,yes i am a dumm ass it was the baeries i swaped some batteries and it worked but i will keep all this info i know i will need it
1 - 13 of 13 Posts
