Alright, so im in the process of replacing all front gaskets including crankshaft seal.
I had to remove everything from the front including the distributor..
This is what i fear, fuckin with that distributor and removing it, and reinstalling it is gonna cause some problems.. I know nothing about timing and TDC and all that shit...
ive been following the haynes manual right but im still worried.
When i pulled the dist. out the rotor turned a bit.
The only thing i marked was the metal base to engine block
And when i took the cap off, it looked like the rotor was stopped on cylinder 3.
then i began to remove the crankshaft pulley, as i was doing that i accidentally turned the crankshaft.... and i could hear a puff of air coming from somewhere...is this bad?
i looked down the distributor hole and saw that the flat head turn didnt turn any... soo..
im about little bit before halfway on the project, i just need to pull the dampener off, then cover and do the surgical work, then put it all back together.
so whats the worst i can expect after this?
And how could i remedy it?
Thanks for any help!!!
