i'm posting my answer to the PM you sent me up here too incase any beginners here needs some help on this as well.
hey so basically all u have to do is put some primer down 1st whats a good primer just a hobby shop 1??? and then for the base gold or silver spray paint or hobby piant??? then u just put down some of that flake stuff or in my post i heard thers paint with flake in it k but what is wet sanding is that like kinda of polishing it smooth??
yeah, a good primer depending on what type of base & paint you using. if you are using laquer you will need laquer primer. if you are using enamel then you can use either normal enamel primer or laquer primer.
rule of thumb is that you can spray enamel over laquer but you CANNOT spray laquer over enamel because of the chemical reaction. the laquer is "hotter" and will melt enamel.
now that i most likely confused you........ lol
ok, i'll walk you through an easy one to try out for starters ok.
go to walmart and go to the automotive dept. get you a can of grey primer. get the "sandable" primer. it should say somewhere on it that it is a laquer based product.
then get you a can of duplicolor metallic silver while you are there.
any shade of silver metallic will work. just remember that the darker it is, the darker your kandy is going to be.
next, go over to the model paints and find you a can of "transparent candy blue" , "transparent candy red" , "transparent candy green" , "transparent candy grape" which ever you want to use.
also to give you a REALLY good shine grab a can of testors "High Gloss" clear #1814
ok, once you have your body ready to spray lay down a light coat of primer. hit it again in about 5 minutes with a nice even coverage making sure you got everything.
let that sit for another 5 minutes or so and lay you a light coat of the silver. again, wait 5 - 10 minutes and give it a good cover coat.
while that sits a good 10-15 minutes get you a bowl or big cup or something that you can fill with warm water and is big enough to put your can of candy paint in. put some pretty warm tap water in the dish and take your paint and undo the seal and everything on the lid so its ready to go.
put your can in a ziplock baggie so it stays dry and lay it in the water for about 3 minutes and then turn it over for another 3 minutes. (the bag helps keep the can dry so you dont drip water on your body while painting)
the reason for doing this is to heat up the candy paint so it thins out and flows nicely. (these candies are notorius for spitting and uneven coverage)
lay down a light coat (just enough to give it a tinted look) wait about 3 minutes and then come back with another fairly thicker coat. wait another 5-10 and do another coat. (warm the can back up while waiting at this point)
NOTE: with candies the thinner coats will give you a lighter tone and more coats will give you a darker shade.
once you have it the way you want, let it sit about 20 minutes and then lay you a nice coat of high gloss clear (repeat 2-3 times)
NOTE: if you plan on using decals, put them on BEFORE clearing. also, let body sit for a day or 2 before applying decals.
this method will give you a nice flake effect. once you've mastered that, there are a few clears that have flake in them (even colored flake) you just have to watch what you get though so you dont have too big of flake or it will look like you dropped it in dirt with wet paint. lol
that is how i did that green impala i posted earlier.........
prime, base, kandy, clear w/ green flake mixed in.
as far as "wet sanding" dumbasses do that on models. :ugh: lol
if you know what you are doing then you dont have to worry about it. (these aren't real cars ya know)
lol
