1 - 9 of 9 Posts
ok its a 6.6 liter pontiac (gto engine) its a daily but i need new carb i want to smoke the common ricer wich aint hard but not have to fill up every 30 minutes. what size do i need
650 holley double pumper..with secondary vac....all you need...not to big ..not to small...but alot of punch when you give it...
There's a mathematical solution for this, I believe you take the cubic inches of your engine, and divide that by the maximum RPM that you plan on runnin' at.This should give you a good starting point, then you need to adjust your high speed air bleeds, and jets to provide maximum performance- a dynomometer would help a lot in that situation.Good luck
1963 Chevrolet
i have to agree with this or an edelbrock 600 :biggrin:
All I know is, this is another case of "Bigger is not better." vacum secondaries are nice for street/gas milage.
1 - 9 of 9 Posts
