I pretty much got a box and 1 unassembled box together, both with 3 ports and pretty much all by rockford fosgate power hx2 specs. I just got a question how the hell do I make the actual sub hole. I have a 10" power hx2and dont know how to cut it. Should I just make a template when the sub arrives and use a jig saw to cut out the hole? Thanks, Chris
Ok now here is the port problem. http://groups.msn.com/BettaPics/shoebox.ms...qAddPhoto&pps=k
Ok on the rockford fosgate web page it says to make 3 ports out of 3" round 16 inches deep pvc pipe and go with 2 ports around the sub and have one port on the back. The problem is the box is 15" tall with a ten inch round magnet. 2 3" 16 long inch pvc ports wont fit, and even if they did they would be about an inch away from hitting the other side. Since I know both of them most likely wont work. How deep sould I make the ports for maximum bass? I already have the 3" port holes drilled. Please help Thanks, Chris
