Ok I have 2 pumps 6batt..... 4 switches....front...back....both rear corners...batt. Are charged.... When I hit the switches nothing happens... All I hear is clicking.....what could I be
how many solenoids do you have? one may be burnt out and not flowing power, or not have a clean ground
if neither the front or back pump works go have the batteries LOAD tested. 1 bad battery will cause the system not to work
this is assuming they were working before. Or if this is a fresh install check ur ground. Might have put ur ground in a weak location. Or check ur wiring
I got 4 solenoids..... I think I got a bad cell on one of the front batt.
more than likely the problem
