Originally posted by team-pontiac@Aug 24 2006, 04:50 PM~6034855
On the doors there is a nut on each side (you do not hve to take off the door pannel) and there is clips along the door side you simply push the molding up and take it out on the top first (or maybe the other way around push it down and take it out on the bottom). the quarter panel moldings is a nut (maybe two) in the rear section of the trunk, I don't remember how they are mounted in front, but I guess there is a nut somewhere behind the rear seat panel. once you've located the nuts it's the same prosidure as the doors push up or down.. It's about 7 years since I did this so I hope I remember correct.
GOOD LUCK!
Robert
