I blew my 2000d and had to send it in to Crossfire to have it fixed (New board is what they told me). So I got it back yesterday and I went to hook it up to my new subs tonight and the protection light is on. I have 2 powers and 2 grounds. The grounds are perfect. I have tried unhooking everything except for the power, ground and remote and it is still on. The green light is on also with the red light.
I have 2 2ohm 15"BL's ran in series and ran to each one of the inputs on the amp which should make them both at 2ohms. What is going on??
Power supply... probally...
Originally posted by Sporty@Sep 21 2007, 05:34 AM~8838773
that amp has a low voltage protection right? is your electric system able to handle the big dog???
Yeah i have a 240 amp alt, Big 3 (0 Guage) and 2 batts. I also have a volt meter hooked up to it to make sure its not dropping too much and its sitting at 13.4 volts.
Your amp is fucked gee every time I sent an amp back to company the amp would come back and play for a while and protect again. Your not doing anything wrong you said you got the big 3 and 0 guage all around and two power sources your strait. go to www.stevemeadedesigns.com for more help or www.realmofexcursion.com good sites go to the forums. hopefully that helped good luck.
Thanks homie! :)
