If it burned immediately u probably ran it on 36v instead of 24v on accident. Or the wire is pinched and shorted out.
Originally posted by 1986monte@May 23 2011, 11:14 PM~20615481
ok, i had some advice from one of the homies on here and it worked from what he said to do, but i just ran into anothe issue i disconected the switch that was bad and when to connect my quick disconnect and it didant spark so i was good there, so i then went to the switch box to dump the front down and the 24vlt wire just burned instantly what could be the issue now , could it off been that i only had one switch hooked up an all the power was to much could that of caused it to do that or what else? if u no i would take yur advice to trouble shoot this issue?
