1 - 14 of 14 Posts
it depends on the painter and color
check out my topic in post your rides :biggrin:
I could get kbc's for around $50 a quart including the reducer (you don't need a catalyst). If you're only spraying the body, I'd say 4 to 6 quarts will do it. It's always better to have a little paint left over than to not have enough, so I say up to 6 quarts.
Also, like "swangin" said, it depends on what color you have. Some colors have a higher pigmentation than others, so you will need less material than with a paint that has low pigmentation.
WTF
HOK kbc18q is 47.58 per qt x 6
HOK sg114q is 55.92 per qt x 6
I thought this was a kandy basecoat?? :confused: :confused: :confused:
This is a 3 stage paint. basecoat, then that sg114q shit, then the clear.
the above products was $618 for 6 qts...and that didn't even include Primer, Reducer, or clear
I'm lost! It seems like it would be cheaper to buy a full Kandy
Originally posted by trudawg@Oct 25 2003, 09:32 AM
WTF
No, it's still cheaper than true candy. Not too much though. It's easier to spray though. You can see how people can pay between $2000 to $3000 for a paint job, the materials aren't cheap. Good luck.
Originally posted by SWITCHCRAFT@Oct 24 2003, 09:37 AM
street sweepaz sprays these alot
where are you bob???? :biggrin:
*** Well actually i mix kandy koncentrates w/ clear alot more... But , these do look good enuff to fool 90% of people out there into believing that you have a full Kandy paint on your car ...... Thats cause it is real Kandy & pearls mixed together.......
IT IS CHEAPER THAN FULL KANDY PAINT.... You need to lay down about 5 coats of kandy paint -- according to the paint books .. you need hardener & that is about twice the cost overall.... Here is real prices out of a book: Enuff for door jambs & all...
1) Base -- Orion silver $115 gallon -- you can find cheaper urethane base for about $75-$90 + Reducer at $25.82/ 2 qts...
2) KBC Kandy Violette $41.61/Qt X 6 qts - $249.66
3) Reducer-- Mixes 2:1 $38.87 /gal.
4) Clear coat -- anywhere from - $70-$300/gal -- thats all up to you on that but , I spend $100 for PPG DCU 2021 -- i get a deal!!!
_____________________________________________________
Kandy: You can bu by the gallon but, im not sure on price..
1) base is the same....
2) Kandy Violette---$49.02 /Qt X 8qts -$392.16
3) Catalyst --$160.05 /Gal....
4) reducer-- $38.87/Gal..
5) Clear-- is same ....
** Remember 5 coats of paint is just about painting a car Twice......
Originally posted by shredder130@Oct 26 2003, 02:38 PM
hey how much will it take to spray my roof on my coupe fwd i took the full vinyl top off and i am goin to put a half top on it :biggrin:
About a quart. A little less.
Originally posted by trudawg@Oct 26 2003, 05:01 PM
If I don't plan on spraying the top because we're getting a full vinyl top, will that knock off a qt or two?
A little less than a quart, depending on your spray techniques.
Originally posted by STREET SWEEPAZ+Oct 26 2003, 04:20 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (STREET SWEEPAZ @ Oct 26 2003, 04:20 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--SWITCHCRAFT@Oct 24 2003, 09:37 AM
** Remember 5 coats of paint is just about painting a car Twice......[/b][/quote]
damn bob pm me your phone number so i can call you and talk about this shit :biggrin:
1 - 14 of 14 Posts
