Okay:biggrin: . I am New to this lowrider deal so bare with me and want my ACCORD to be phat:cheesy: . I have a few questions and am hoping that you guys can help me with it. Thanks for helping a brother out.
:cheesy:
1. What kind/power of hydraulics should i get ? Air cyclinders?
2. What kind/power of compressor should i get?
3. What kind vavles do i need for them?
4. What do i need besides a tank, valves, air hose, air cyclinder, compressor and switches?
5. If i get a kit, which one do you think is best for my ACCORD?
:dunno: :dunno: :dunno: this guy reminds me of somebody
but what i cantell you is get the cylinders that are right for your car fatter the better i believe you will need 8 poppet valves or 4 spool valves, parker pop valves are the best bet and besides all of what you listed you might need guages, battery switch, and pressure switch and the fittings.air dryer and blowoff valve
don't get a kit just find out what you need from here and get stuff from diff places ot can be cheaper or if you get some good shit from one place talk about them cutting a deal but with the stuff that you want
Originally posted by snko916@Aug 4 2003, 06:16 PM Okay:biggrin: . I am New to this lowrider deal so bare with me and want my ACCORD to be phat:cheesy: . I have a few questions and am hoping that you guys can help me with it. Thanks for helping a brother out.
:cheesy:
1 - hydraulics are a completely different set-up all together. You want to get Air Cylinders, Go to Easy Street or AIM Industires to give you an idea of what to look for.
2 - The compressor depends on you and your play time. Most ppl buy Viair, Thomas (common kit comp), Blow Jax
3 - This also depneds on what you would like the set-up to do. Front, Back, s2s, you will need 8 2 - way valves, 4 spool- type (not sure check witt JoeBomber or Big Dan on these).
4 - ??
5 - Hit up Easy Street, AIM Industries, M.I.C., Showtime Hydraulics they have Euro kits made for Honda's.
Thanks a Whole lot :biggrin: , this as helped me a bunch. thanks foey, thanks bomber. You have helped me a lot and i thank you for your time. :biggrin:
yOU SHOULD GET A AIR CYLINDER KIT KIT OFF OF EBAY. CHEAPEST I HAVE SEEN. MAKE SURE YOU GET SMC OR PARKER VALVES. tHEY USUALLY COME WITH A BLOWJAX COMPRESSOR BUT YOU SHOULD UPGRADE TO BIGGER COMPRESSORS OR EVEN USE NITROGEN.
for that accord get like a 5 gallon and a blow jax or a 100% duty cycle compresser with good ratings and also run a scuba tank or nitrogen if i could fit that in a mild civic you should have plenty of room in the accord
hell, you might even be able to pull of a dogleg on that car...
get at least 1 blowjax compressor, a solenoid to handle the load of the compressor, a pressure switch, some gauges, its also nice to have a gauge that reads tank pressure, switches, etc, etc..
Originally posted by bigdanmcintosh+Aug 5 2003, 01:29 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (bigdanmcintosh @ Aug 5 2003, 01:29 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--joebomber52@Aug 5 2003, 11:42 AM this guy reminds me of somebody
Related Threads
LayItLow.com Lowrider Forums
17.7M posts
191.1K members
Since 2002
