1 - 2 of 2 Posts
My current problem is that when I drop the front of s10 the passenger side goes down a little further then the drivers side.
Do the hoses have to be same length or is there a maximum length that you do not was your hoses go past, for example if the driver side hose is 8 feet and the passenger side is 12 is that to much?
Any help would be appreciated.
it sounds like ur cylinder might be bent on the driver's side..
>the hose lenght SHOULD be the same lenght...but for basic fbss it wouldn't affect it that much.. If you have two dumps going to the front, and the driver's side is still higher, then its i'm almost 99% sure its a bent cylinder
1 - 2 of 2 Posts
