I am putting the ports in tommrow , they are going in a 2 12" box, I have some 4in cardboard tubing that I was thinking of using, any suggustions the box is the box is 1 ft 3in back, 3 ft long, and 1 ft 2 in. down
Are you talkin' about the Ground Zero 12" DVC Nuke??? I hear that's an awsome sub...Originally posted by bigLINCOLN77@Oct 8 2003, 11:44 PM
they are two Sub Zero gold series DVC , 600watts each
How can I have one port with a 2 12" box? thanks for the information, and where exactly should I put the ports, on the same side as the speakers? or somewhere else, on the top of the box, somethin different?
I am putting these ports in as soon as I get the info for them, and I will let you know how it sounds asap
Depends on teh desired tuning frequency.Originally posted by bigLINCOLN77@Oct 9 2003, 06:11 AM
I decided to build a one slot port in the center of the box, how wide should I make it, and how far from the back of the box
or should I make two slot ports in the center? with a dividing wall between them
I need to know how many inches wide each port should be, or for a single port if suggusted, thanks
^^Originally posted by JeremyD@Oct 9 2003, 06:26 AM
If you could post the T/S parameters for the subs it would certainly help....
lol....thats wrong in so many ways....not even going to try to clarify...Originally posted by DustinN@Oct 14 2003, 02:39 PM
To figure the port size out first off you have to find out what frequence your car resinates at, then get a box tuned to that freq. That way it will sound good with any note
