i wanna put a lcd in my steer wheel....... in my 93 caprice, but i need to know how to disconnect the air bag, so i can pull it off then gut it out...........
thanks!
thanks!
I've tried it in a junkyard, does'nt worklOriginally posted by Chris@Aug 4 2003, 02:20 AM
hit the sensor in the front end..........it will deploy and then remove all the shit
I know you was being sarcastic :uh:Originally posted by Chris@Aug 4 2003, 03:34 AM
i was just bein sarcastic too..........your an idiot if you start messin with that shit.......but did the car in the yard have a battery hooked up and power?
oh. because theres this junkyard where you can pull your own parts, and there was this 92 caprice, and the sensor was exposed, so I was beating the shit out of it with the hammer, trying to make the air bags pop out, but I did'nt know that you needed the battery attached though.Originally posted by Chris@Aug 4 2003, 03:39 AM
you would have to hit it with a fair amount of force pretty much a car traveling at around 30 so.......
It is labeled airbag.Originally posted by PS2MODCHIP@Aug 4 2003, 09:53 AM
DO YOU KNOW WHICH FUSE IT IS? OR IS IT LABLED "AIR BAG" ALSO..... WHERE IS THE PLUG YOU WERE TALKING ABOUT IN THE STEERING COLUMN
