1 - 11 of 11 Posts
Ok this weekend I m going to finish install all my set up is going to be 2 pumps,4 dumps,ten switches and four batteries. What I dont understand is that theres two wires for the front pump and two wires for the rear pump. My question is that if I can wire the two wires for the front pump together to the selenoids will this effect anything. :)
dude u need to check out the tech section lil wires every where it was like second nature to me to wire the switches 12 of em to b exact good luck :)
I don't understand how you see you see two wires to the front pump. You have 2 pumps and 4 dumps. This should be a total of 7 wires.
1 wire to the solendoids that operate your front pump.
1 wire to each dump on your front pump
1 wire to the solenoids that operate your back pump.
1 wire to each dump on your back pump
1 24 volt wire
The other wire on your dumps are grounds. These wires can be tied together for one ground.
Hope this helps.
later
TC
See I got nine wires coming out of my switchbox
1 to the front pump
2 for the two dumps for the front
1 to the rear pump
2 to the two dumps for the rear
1 hot 24 volts
Ok I got you there about the seven wires but I got two wires left so that equels 9 wires. :)
Why wouldn't you be able to? Just curious.
If you get two more pumps, it will be a little work because you will have to re-plumb your pumps and get more solenoids.
Oh but it will be well worth it in the end.
by no means am I telling you what to do. I remember when I had two pumps and I said "this is all I want". Now my car is overkill.
Just my .02
Later
TC
u got to have the right switches 6 prong, for side to side 12 for see saw and pancake..
get some diagrams from the prohopper.com or layitlow.com website, and try to understand them, not copy, but understanding! If you do, you can easily make your own custom diagram, and decide what the switches do and in what order they are ;)
Hey thanks man ;)
1 - 11 of 11 Posts
