1 - 20 of 31 Posts
I got a prewire ten switch box and two valve spools, My only problem is wiring them to do fbss and suck one up. Does anyone know how? I would greatly appreciate it.
Face Puncher
post a picture of these four way spools
I've never heard of 1 valve being able to control 2 cylinders like you're saying these can...
Go to streetbeatonline.com click on air suspension then air management and scrool down alittle there Is a 4-way valve spool, That is what I have. I'm getting one for the front one for the back. They told me two can do fbss & suck one up. I'm going to work on it in about a wk so I hope it goes smoothly!! Anyone with suggestions--holla-
Face Puncher
heres a pic from my website.
the valve you're using is the same..
the point I'm trying to make is, you cannot suck 1 wheel up with only one valve... because the cylinders are tied together..
so, when you hit the switch for drop, it's gonna retract both cylinders.
you need at least 3 valves to do what you're wanting to do..
is this making sense?
Discussion Starter · #18 ·
I drew a diagram just like that while planning to do my install.
Anyway, these valves are 4-way valves and according to the shop
that I bought them from, I can suck one wheel up because they
are double acting cylinders? I'll just have to wait and see after I
install tham!
1 - 20 of 31 Posts
