1 - 20 of 26 Posts
I HAVE A 1995 ACCORD WAGON WITH AIR RODS AND I WANT TO KNOW HOW TO DO 3WHEEL IN THE BACK STANDING HELP.
yup, but the spool valve will make for an easy install on that application..
you need a double acting cylinder, and eithr 4 poppet valves or 1 spool valve..
whaich do you want to use, I'll draw a quick diagram for ya..
Originally posted by bigdanmcintosh@Jul 30 2003, 09:04 PM
i dont believe so...
some just have little tiny "vent" holes...
i dont know dan the little vent hole on mine is a half in wide and has threads so my guess is ..........its ported
ok they went way to far into that shit........ if you have four corner suspension on a euro you drop a left or right front at a high PSI and the diagonal wheel should lift, obviously 3 can not be attained wit only front back suspension, try that it's a lot easier, what they are talking about is the "suk up 3" which you still have to do what i said to do that so do a basic 3 just drop one of the front corners and if you want the wheel to go up in the fender combine what they said.
Discussion Starter #20
i tried it but it hit three but i could not get that corner to go up the press cuming from the bottom would not realese so that corner was stuck on three all the time. help :(
1 - 20 of 26 Posts
