1 - 11 of 11 Posts
i'm currently trying to clean up the rear axle housing that has 25 years of road grime on it pluse a nice thin coat of rust....
i can't really sand blast the parts because i don't want sand all over the place... so i need an alternative..
are there cleaning agents, acids, etc that i can use... i need the metal to be ready for welding which means it doesn't have to be gleeming, but i would like to have the metal exposed to get a good weld.
any help would be appreciated!!!!
Soak it really good with WD40 2 or 3 times a day for 2 or 3 days in a row.... everything will wipe off with a rag.
But if you plan to paint it, you need to make sure to use a good degreaser (like Formula 409) to get the WD40 off before you try painting it.
is the frame off the body?
if the frame is off and free of components, heat water till its scolding hot with a wd-40, then use a wire brush and get to work.
you'll be amazed at how well this works. it also leave the metal ready to weld.
give it a try, you'll be amazed.
:cheesy: ,
cc
:cheesy: ,
cc
What do you mean 'heat water with a wd-40'?
chris
Originally posted by WashPaChris 64+Sep 11 2003, 06:04 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (WashPaChris 64 @ Sep 11 2003, 06:04 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--Cruz_Campos@Sep 10 2003, 06:04 PM
:cheesy: ,
cc
chris[/b][/quote]
heat water with an electrical stove top in a coffe pot, or whatever and you can either add wd-40 to the water or spray a little bit on the frame.
you can just use water, but it has to be scolding hot.
thats it, you'd be amazed out how good it works.
:cheesy: ,
cc
Just a corse wire brush (wheel) on an angle grinder will do the trick, no need to start a home science project guys.. geez..
Does it have undercoat or rust?
1 - 11 of 11 Posts
