1 - 11 of 11 Posts
Super Triple Double OG OG
you have to undo the cylinder from the bottom, wheater it be a power ball, or just a nut and bolt through the end of the cylinder.....
but before you do that... jack the car way up with a jack and jack stands.... release all pressure from the cylinders... remove the hose, then undo the cylinder at the bottom....., slide it right down.........
what i did with my impala was i raised the car about 6 inches so the cylinders are almost empty and jack the rest up, once you start doing dat, you hear the coils start to move around, i didnt know you cant coil over the fronts!
Yes you can set them up in the front.
x2
couldn't have said it any better :biggrin:
1 - 11 of 11 Posts
