How many Dumps should i run in a 4 pumps 12 batteries (2 bays of 72V each) 8' cylinders front and back set up? :uh:
It depends on what you are going to be doing with the car! Some people run 3, 1 to the 2 front pumps (hopping applications mostly) and 1 to each rear pump and then some people run 4 one to each pump!!
nicely said ;)
Run 1 dump for each pump. Makes wiring simpler. And for basic setups who needs more than 1 per pump.
My statement was for a 4 pump.
if you want four corner play you will need to have 1 dump for each pump..timdog was pretty much on the money with his reply...it all depends on what you plan on doing with it..if its a street car i would say 4 dumps 1 per pump....hopper dumps...2 to the rear and one for the front pumps
