1 - 10 of 10 Posts
I am lowering the volts on a set up its currently using 96 volts and i want to run it at 48 volts. I went ahead and made it into a 2 bank system but i just can remember or better yet double check if i should remove 1 solenoid and have only 3 running per bank.:confused:
How many solenoids would you want for 72V? How many did you have for each pump when you were running 96V... I have been having issues with my solenoids lately and cooked a motor on the weekend...
I have three per pumps (two pumps at 72V and the lone rear at 48V)
48 volt three for front or 2 for the rear pump..2 batteries per one noid old school rule of them..make sure they mount to a welded ground..
2 accumax's per pump, keep barrage charged and you won't have problems.
1 - 10 of 10 Posts
