All old wives tales. Running 1 or 100 solenoids in series has absolutely nothing to do with the amount of voltage they can handle. Multiple solenoids merely acts as a safety device, ensuring that if one solenoid welds together, there is another one in the series that can open the circuit.Originally posted by lowmerc@Nov 14 2003, 09:57 AM
" The unwritten rule is three solenoids PER PUMP regardless of the number of batteries. "
Dare I ask why? I thought it was 1 per 12v.
actually, it's one soleniod for every 2 batteries... but it's most common and safe to run 3 solenoids per pump... when you start getting into HIGH voltages, then there are always exceptions...Originally posted by lowmerc@Nov 14 2003, 07:57 AM
AMEN, FINALLY SOMEONE WITH A GOOD POST ABOUT SOLENOID USE.Originally posted by Cadillac Bob@Nov 14 2003, 11:42 AM
So long as you run a minimim of 2 solenoids per pump, you will be fine. Running 3 per pump, will give you a third "safety". Running more than 3 per pump, is just simply overkill and not neccesary in most normal circumstances.
thats using one to trigger the bank of three?Originally posted by ogcaddy@Nov 15 2003, 09:40 AM
AND IF YOU WIRE THEM LIKE HYDROTA DOES, YOU ARE EVEN BETTER OFF.
thats using one to trigger the bank of three?[/b][/quote]Originally posted by air280+Nov 15 2003, 05:45 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (air280 @ Nov 15 2003, 05:45 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--ogcaddy@Nov 15 2003, 09:40 AM
solenoid blocks are CRAP! so are them rebuildable monster solenoids (the work good at first, but when they burn, theyre garbage!)Originally posted by Cadillac Bob@Nov 14 2003, 08:42 AM
Its a nice clean setup and has been performing great for me. The car is a hopper and daily driver in the summer, so it sees lots of action. I used to blow blocks like mad on the front, and since I switched to the accurates I have had no problems.
I do it with 3 and 3.Originally posted by Hydros@Nov 17 2003, 04:22 AM
I use four, in series and parallel, 2 and 2
Maybe I've been just lucky, or was I unlucky with three?
Three always sucked for me, until I spread the out load. I only stuck once with real dead batteries using the four. Using three was always a problem.
I have never seen anyone wire them up the way I do, yet it's the only way I will ever wire them.
