Hello! :cheesy:
216RIDER got me thinking about ride heights the other day :angry: :biggrin: !
Because I can't use a bolt on kit for my car I'm going to have to estimate the height for my air spring mountings. My car is a full size 1967 Oldsmobile, so I'm guessing that the suspension, although not identical, will be similar in its geometry etc to a 1960s Impala.
What I'd like to find out is how much drop from standard ride height do you get before the car is on its bump stops (or hitting metal if bump stops are removed)? This would give me an idea for a starting point for mounting spacer heights because I don't want to be wasting any of the springs' capacity if I start in the wrong place.
Originally I was going to try and get the air springs at their design height when my car was at its original ride height, but now I'm wondering if I should start a little lower.
Has anyone with a 1960s Impala (mentioning no names
) worked out their air springs' actual height at 100psi on the car, compared with the 100psi figure given by the manufacturers? I expect it will be a bit shorter with a car sitting on it
