1 - 5 of 5 Posts
I need for an 82 electra 4 door base and claer, also adding flakes. How much of everything will I need??
** You shoulda just called me out ......You will need to buy a gallon of base-- it is cheaper to buy than 3qts & just in case you need to make a repair..., at least a gallon of clear -- depending on flake size, buy 2 cans of mini flakes/ regular flakes.... the larger ones take too much time/clear to do....( you have to wait till the flakes in the clear "Flash off" & then you take a vinyl glove & you lay your hand on the paint & actually lay the flakes down by hand..) Then you shoot about 3 more coats of clear, wait a day or so - depending on temp - & then you wetsand & buff out.....
1 - 5 of 5 Posts
