there's a 13" bag, but it's only for rear applications. As for the front, HS Slams up front will do you right.
a normal bag up front will lock out your a-arms.Originally posted by T-Guns@Aug 15 2005, 09:43 PM~3630387
Im getting ready to order bags for my 79 cutlass and i was wondering if anybody knew how much travel my suspension gets? Id like to get bags that will give me the most lift or travel like from laid out up 8 9 or 10 inchs but im not sure if it would bet worth it to have bags that have 10inchs of travel up front if the car wont even travel that much. What would you guys recommend for bags im thinking of going with slams im not sure who offers the most lift thanks alot
the trailing arm cross member wont alow them to be monted on the armsOriginally posted by blznnp@Aug 15 2005, 11:37 PM~3632934
like mark said, a normal bag should lock up your front, you can get those 13" lift bags, i have only heard good things about them, or you could mount the bags on the trailing arms to get a little bit more lift, but i am not sure how strong the arms are if they will be able to take the bag pushing on them, but for the most lift in the rear, the 13" lift bags over the axle will get you the most unless you mount the bags to the arms.
when all else fails, weld a square tube brace in it's place and cut the fucker off the car..Originally posted by Mark@Aug 16 2005, 01:40 AM~3632951
