How Do you put on Viynl tops such as: Landau top, Half top, Full top Halo Top.
the BEST way to do any top is to remove all the windows where the vinyl is covering and reinstall them after the top is glued on, but you can get away with taking the window trim off and cutting the vinyl into small over lapped sections that can be tucked inbetween the window ant the top and when you put the trim back on you wont be able to noticeOriginally posted by A-Run@Sep 24 2003, 06:30 AM
what about around the back window? how do you get it tucked back in and sealed?
its not too bad.. the hardest part is making sure the seams are glued down straight, and making sure the areas where the roof curves down are wrinkle free...Originally posted by A-Run@Sep 26 2003, 12:13 AM
sounds pretty damn simple
that really depends on how delecate the fabric is... if its real delecate your not gonna want it on your roof anyways... but i guess you culd try scotch gaurding it... and if its really thin you may have troubles finding a good ahiesive that wont destroy it or bleed through...Originally posted by A-Run@Oct 3 2003, 11:12 PM
Im thinking of just covering the existing vynil with this material but not sure if it would work, dont know if maybe I can weather proof it or somethin...
its white in white so you cant always see the roses
(Wild Irish Rose) is the cars name
the BEST way to do any top is to remove all the windows where the vinyl is covering and reinstall them after the top is glued on, but you can get away with taking the window trim off and cutting the vinyl into small over lapped sections that can be tucked inbetween the window ant the top and when you put the trim back on you wont be able to notice[/b][/quote]Originally posted by Chris+Oct 4 2003, 10:30 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Chris @ Oct 4 2003, 10:30 PM)</td></tr><tr><td id='QUOTE'>how would you do a top on like a caddy where at the back window or goes around all the trim and stuff?
<!--QuoteBegin--A-Run@Sep 24 2003, 06:30 AM
