141 - 160 of 186 Posts
What clear have you found works best? its been some time since ive built any, but looking to get back into it :D
the clear I use is the Dupi-color paint shop quart BSP300 - Clear Coat from auto zone its like $25. I shoot it though my airbrush depends on the weather 30-45 psi
is it an acrylic clear? or does hardener have to be used?
I know in aus things go by different terminology - for automotive paints its usually acrylic or 2pac
Brick City
Discussion Starter #146
I always use Urethane automotive clear, slick it out with an airbrush, wet sand it flat with 3400-12000 grit polishing pads, n then rub the crap out of it with a micro fiber and Meguire's Scratch X. Will look like glass when you re done!!
Brick City
Discussion Starter #147
Here Paul Pacheco... I bumped It up for you fam!
Screenshot_2014-03-01-09-33-02-1.png 61 i started but never finished might have to redo it some day this is hok and kustomshop
Screenshot_2014-03-01-09-36-13-1.png 64 diecast also hok and kustomshop kandy Aztec gold
Screenshot_2014-03-01-09-36-43-1.png Kandy N Chrome inspired top
Brick City
Discussion Starter #153
I JUST REALIZED THAT THIS THREAD HAS BEEN VIEWED OVER 18000 TIMES!!!! That's awesome!
Question about Kandy patterns
Hello,
First off I have to say beautiful tutorial! This was very helpful for me to create the killer looking effects! Also the builds on this forum are just plain awesome!
I gave your pattern technique a go on one of my diecast cars, but I still have some questions…
The picture below shows you my result I got so far, but the problem is the pretty huge “ridge” I ended up with. First the top got a coat of mini silver flakes then taped up the panels, Airbrushed some patterns on it with black and gave it a coat of HOK Kandy to finish it off.
When I pulled the tape I ended up with a “ridge” witch is of course normal, but I already needed to put on 4 coats to even it out a bit. So I think my combination with the black made it a bit too much.
So my questions are:
- Do you guys have a limit to the amount of “graphic” coats you put on? Like A difference of 3 coats is too much for a modelcar? Most Kandy patterns I see are done with just one coat difference.
- How many coats of clear do you guys mostly put on a model to seal (even out) the patterns?
- With witch sandpaper grid number do you sand the model after the first coat of clear? And after the second, … ? Before the buffing process starts with the 3400 up to 12000 grid (if you like)
The painted top:
I think I will have to go for this effect instead if I want to keep the black patterns without the "silver line"
But with the silver line you can create some cool paintjobs
So thank you for sharing your' e techniques with us to make even cooler rides!!
Grtz
Ill do a how to on my next paint project. That 39 came out sick Chris:thumbsup: and that camaro sinacle came out sick you got down homie:eek:. Heres my most recent wish i would have took more progress pics. But next time I will.:cool:
I know this was posted up a year ago but I'm diggin this car and paint scheme! Art what colors did you use on this? And which did you lay first? Thanks
THIS IS MY FIRST ATTEMPT EVER AT PATTERNS. AFTER STUDYING THIS THREAD AND OTHERS FOR WEEKS I FINALLY GAVE IT A TRY AND CAME UP WITH A DESIGN I LIKE. TOOK ME ABOUT 16HRS OF MASKING..I NOW HAVE GREAT RESPECT FOR YOU GUYS WHO DO THIS ON THE REGULAR MODELS AND 1:1. HERE'S MINE IT WAS DONE OUT THE CAN, CAN'T AFFORD A GOOD AIRBRUSH YET BUT I'LL GET ONE SOON.
