I just got the '39 Chevy Coupe Lowrider model car and wanted to open the doors and trunk but how do you hindge the doors and trunk. :uh:
wouldnt solder be to weak to hold the shape when opening and closing the door :dunno:Originally posted by tRiCk oR TrEaT@Jul 31 2003, 12:41 PM
the way i've alwayz done it.... iz... go to dunkin dougnuts n get one of those brown coffe straws.... and then get solder... put the solder inside the straw cut it to the size and do the L shape but the str8'n it back out and glue it by the inside so the door is aligned right.... but glue it with hot glue or crazy glue so it holds good... then after its dry the door should open and close....
wouldnt solder be to weak to hold the shape when opening and closing the door :dunno:[/b][/quote]Originally posted by lowcrome+Jul 31 2003, 12:56 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (lowcrome @ Jul 31 2003, 12:56 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--tRiCk oR TrEaT@Jul 31 2003, 12:41 PM
Originally posted by h-town's playa@Aug 1 2003, 03:08 PM
[/img] ]http://www.imagestation.com/picture/sraid7...g.orig.jpg[/url][/b][/quote]
you got the img'z backwards.
