1 - 12 of 12 Posts
I have a 1971 Impala with 18" telescopics in the rear. After the first stage is out, I realized that the brake hose causes a bind. It goes to a T fitting, and stops the car from raising any further... I need to make this brake hose longer.
Anyone have any suggestions?
Thanks,
YL.
Thanks,
YL.
they should sale brake lines at your local autopart store. just get one thats longer then the ones thats one there. your gonna have to bend it yourself though.
I guess I should mention that I work at O'Reilly Auto parts. We don't have anything that will work in this application.
All we have is stock replacement. What I need is a custom HOSE, not hard line. It has to be flexible. (18" of travel man, eighteen inches!)
Besides the hose on there is flexible, because of where it is located. It runs from the car to the rear end.
Thanks for the advice on the Caddy, Krewl. I like answers like that one... I might have to do that...
YL.
YL.
There is one for something but I don't remember the part number. :angry: Unhook the hose from the line and take the line out of the frame and bend it down, don't worry about hooking it to anything it will be fine. Unless you dropped the trailing arm mounts you won't use even half of the cylinder. I don'y know what pumps you are using but all the ones I've ever used would snap the brakeline easy.
I have a part number at the shop it should work, get back at you tom..
i'm guessing the hose that gets taught is the 'flexi' join, i had a set of three stainless hoses made up longer than stock at a place in the US and posted back to the UK pretty cheap (couldn't get the right fittings here in the UK), the place i used was www.racepartsolutions.com well worth a try in my opinon.
1 - 12 of 12 Posts
