How To Make A Red's Dump Catridge into a
3168 Views 22 Replies 20 Participants Last post by  84Joe
14
How To Make A Red's Dump Catridge(with internal slow down Valve) into a Blow Proof Dump Cartridge.........Ok ,Here's a quick tutorial that does work and I've tested the dump catridge out with 4-6-9 batteries with excessive abuse put to the dumps and it still wont blow or internally leak...... wonder why red's didnt think of it....oh well,
first you will need some polyurithane o-rings which I got from Martin Fluid Power(in Phoenix)
Part# OR-010 and OR-011
here we go....here's an old red's dump with built in slowdown valve,the dump itself is not internally reliable but it sure is accurate when you hit the switch,there is no delay but this dump is notorious for internal leaking and most as well as I consider it as junk but after we add our orings it will be good to go with no problems....
Unscrew the coil nut and remove the coil..
Unscrew the cartridge from the dump.....
Now you have your cartridge...
You will need some vice grips and a adjustable wrench to take apart the dump...
Once you have it apart it will look like this.....
Now get your 2 O-rings ready...
First O-Ring(part# Or-011) will go into the catridge housing......
Make sure it is flush at the bottom,I use a writing pen I took apart to push the o-ring down to the bottom of the cartridge housing...
Next you will put another o-oring(part# Or-010) on the top of the cartridge piston pin guide.....
The piston pin guide will look like this when its on there.....
Now Put the dump cartridge back together.....
Here's what it will look like when its all back together.........
All thats left is to screw the catridge back on the dump block and install it back on the pump....
FYI: also on one occassion only I had to cut 1 turn of the internall spring because there was too much tension pushing on the catridge piston,but everyone(and Ive done 10 of these dumps) after have worked without having to cut the internall spring.....
I know some of us have alot these dumps sitting around in the garage,or use them as paper weights.....lord knows I have a few of them which I fixed and tested ...I sold a few of them I fixed to couple of my friends and there running them in there cars now with no problems.......hope this tutt helps.... :cheesy:
1 - 20 of 23 Posts
Very Innovative! :cheesy:
You saved me a few bucks my man, which means more gas for crusing to us "budget lowriders". hehe
Good info and documentation!!!
awesome ,
Cool, does anyone know who produced these valves or have a part number? I would like to get ahold of a couple if anyone has any for sale.
Thanks for sharing this! Great info. :thumbsup:
i always wondered how are you supposed to tighten the nut on the slow down valve, when the slowdown valve head is bigger than the nut.....
GOOD SHIT TO SEE OTHERS SHARING TIPS AND IDEAS.... :thumbsup:
:cool: i used to have some of those back in the day. long gone now!
Manufactured by HYDRAFORCE the materials weren't very good and accuracy was marginal at best.
Awesome!!
I have these in my low and my L/F has the internal leak issue. I will have 2 get me some teflon o rings now and fix em up. Thx homie!! Ur a life saver. I was gonna get new ones from BMH but now I can put that money towards something else. This also saves me from havin 2 get new return lines as mine are hardlined and swagelocked. Thx again homie!!
nice homie !
:thumbsup: :thumbsup:
They were made by a company called sterling
Bravo on this topic good to see good in depth tech stuff on LIL. I used to have those same dumps back int eh day before switching over to Adex dumps when I got annoyed with leaky dumps
Big Ups.. Always good to save money.
1 - 20 of 23 Posts
