1 - 3 of 3 Posts
depends on what car it is... on my monte it is glued in.. you just gotta carefully peel it off... then i unbolt the channel that it is held in so i can scrape out all the old glue easyer and put it back together, and glue in the new weather stripping...
if you pull it back a little you can see small clips that hold it in, there is a special tool that you can buy to squeeze these clips but I tont know what its called... Im guessing you could just use some pliers or something as well, Ill see if I can post an image of the tool bro just to help if you need it
1 - 3 of 3 Posts
