YOu have to take some pliers caller channel locks.There is a spring in there that is held by that pin. You have to take the channel locks and put one end opposite of where the kickstand is and the other where the ring is on the side where the pin is. When you compress the spring with the pliers, the pin will loosen and you can pull it out. You might need another set of pliers to put it out.
