Originally posted by biggeazy-e@Sep 6 2006, 08:04 AM~6114577
i better go unplug mine.. i thought it was a vent(fumes out) and didnt want my engine bay to explode....
It probably works both ways. From what I know the engine would pull vaccum on that line and keep any fumes from getting into the atmosphere.
If the car is sitting and the tank heats up then to relieve the pressure inside the tank the vent would have fumes coming out of it and while the engine is running and pulling fuel out of the tank it's letting air in. With such a small line there probably wouldn't be hardly any fumes coming out of it compared to having 20 gallons of gas in a bathtub.
On my 73 Nova I have a steel line and it ended by the rear of the left front wheel housing off of the undercarriage and I took a small section of rubber hose and put one end on the steel line and the other end I have a PCV valve on it. My reasoning is the PCV valve will let air in and pressure out in a somewhat restricted fashion and I'm thinking if fluid (gas) were to come out the line it would also seal up somewhat. PCV valves are cheap and I don't know how really well they seal up but my thinking was it was a valve and while I didn't want to leave the steel line open I'm thinking it is working like I wanted it too.
I know there is not a ton of fuel flowing out of the stock lines when driving the car and was reminded of this while working on a customer's 56 chevy with an LS1 motor in it and an intank fuel pump. We had problems with the sending unit and to make it easier to get the gas out of the tank I disconnected the line on the frame and put a catch can under it and turned on the ignition. It took a while to pump out 5 gallons of fuel. Now I have seen rails and funny car fuel systems and those have 1-2" diameter fuel lines on them off of the tanks and those burn a LOT more fuel than most cars out there.
Jim
