How would this work for notching my frame?
515 Views 3 Replies 3 Participants Last post by  joebomber52
I cut out the rear of my cutlass and was going to make my own notch, but saw this one and was wondering if it would be good or not.
what size wheel are you running to need that much room for your axle?!!?!
anywayz, a pic does us no good. is that box or c channel? how thick are the walls?
I have no size comparasson but they dont look like they level back out enough to flow smoothly into the rest of the frame...
I changed my mind I am building a custom notch. That notch is 2x4x.120. and I doubt it would work because I want to be able to lay my cutlass out on 24's but cruise on 22's.
if your going to use a notch of that style you will want to put the frame in a jig for best results
otherwise use a 4 peice set up
