http://www.surpluscenter.com/item.asp?UID=...tname=hydraulic
Anyone ever try these valves? $59.00
SOLENOID OPERATED POPPET VALVE
New HYDRAFORCE. Solenoid operated 2-way poppet type valve. Use for starting, stopping, or dumping of hydraulic circuits to 3000 PSI. Continuous rated solenoid with hardened seat for long life and low leakage. Rated 12-15 GPM ports SAE 8. Shpg wt: 2 lbs.
12 VDC, normally closed, 1.67 amps.
