1 - 20 of 40 Posts
What type of fluid is best?
I just have been useing hydraulic fluid.
I have heard about using motor oil also.
Which is better for competition?
NON DETERGENT 30 WEIGHT MOTOR OIL
;) :biggrin:
i was watching some machinery mover show last night and they were using vegtable oil in their hydraulic setups... never heard of that? has it ever been used in our case? if so what was the outcome?
Trevor
atf-3
cc
SINGLE PUMP NO WEIGHT
Originally posted by big pimpin+Oct 16 2003, 08:12 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (big pimpin @ Oct 16 2003, 08:12 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--hydrota@Oct 16 2003, 09:02 PM
hydro fluid
:0[/b][/quote]
in the winter i cant get the 30nd to work. the hydro fluid does
I don't hit switches in the winter.....that much. :)
R & O HYDRO FLUID!!!!!!!!!!!!!!!!!!!!! :0
Originally posted by hydrota+Oct 16 2003, 08:17 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (hydrota @ Oct 16 2003, 08:17 PM)</td></tr><tr><td id='QUOTE'>
hydro fluid
:0
in the winter i cant get the 30nd to work. the hydro fluid does[/b][/quote]
just depends on where you're at...if you live in a cold area then hydraulic fluid is probably better
Originally posted by nissanminitrucker@Oct 17 2003, 08:16 AM
I use Tranny fluid..
:uh: :uh: :uh:
tranny fluid is the worst thing to run in your pumps.... except maybe for water, gasoline, or kerosene...
Originally posted by hydrota@Oct 16 2003, 07:02 PM
hydro fluid
:thumbsup: :thumbsup: :thumbsup: :thumbsup:
the worst thing about hydro fluid is that it's a little harder to wipe off of yourself if something blows, like a hose or fitting... :(
Originally posted by nissanminitrucker@Oct 17 2003, 08:22 AM
i use tranny fluid because it is thinner.. i like it because of that..
Which is exactly the problem. It causes premature wear of the metal in the gears in pumps like we use... especially aluminum.
1 - 20 of 40 Posts
